John167
Apr 09, 2022Follower
7200 doesn’t see my router
My router light will not come on. Device light is green. Help
Apr 10, 2022Guru - Experienced User
What model do you have?
Device/router light implies you have an extender.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
