Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
Aug 09, 2021Guru - Experienced User
Did you try a factory reset prior to the downgrade?
Anytime there's issues after a firmware change, thats the first step I recommend.
- Hopper15Aug 09, 2021Star
I did try a factory reset with my router before downgrading the firmware along with rebooting my router multiple times and rebooting my devices to see if that would fix this issue with Mozilla Firefox. Unfornatelety none of those troubleshooting steps worked. This is clearly an issue with this new firmware as I have run into absolutely no issues with mozilla firefox since downgrading my firmware.
