Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
Hopper15
Aug 09, 2021Star
I did try a factory reset with my router before downgrading the firmware along with rebooting my router multiple times and rebooting my devices to see if that would fix this issue with Mozilla Firefox. Unfornatelety none of those troubleshooting steps worked. This is clearly an issue with this new firmware as I have run into absolutely no issues with mozilla firefox since downgrading my firmware.
Aug 09, 2021Guru - Experienced User
was the issue only on Firefox?
Or did other browsers have the issue as well.
- Hopper15Aug 09, 2021Star
Just Firefox for me. But it's the only browser I regularly use so I can't speak for other browsers.
- AgriusBAug 10, 2021Aspirant
This is happening for me in all browsers and I'm having weird connection issues in games. In minecraft the game randomly says I'm no longer authenticated when logging in. Though no one is having connection issues to my server. This is on a wired computer.
A wireless device on the network has to restart the computer every time I reset the router otherwise they have no connection even with it saying they're connected.
Update:Factory reset did not fix the issue. Going to revert to the previous update
- Retired_MemberAug 11, 2021
I had this before the firmware update. This how I fixed it.
Go to router advanced home and note the dns entries.
Go to windows control panel and click on ‘Network and sharing centre’
Click ‘change adaptor settings’. DoubleClick the ethernet adaptor click properties,
highlight Internet protocol version 4(TCP/IPv4) click properties:
Click ‘use the following DNS server address’ and enter dns numbers in the ‘preferred dns server’ box.
you could also use 8.8.8.8 for Google or 1.1.1.1 for Cloudfare
Hope this helps
