Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
Retired_Member
Aug 16, 2021Same exact issue here, it's kind of crazy how hard itr is to get support for this. I'm not interested in setting manual DNS entried on every device to circumvent what the router firmware update borked.
Hopper15
Aug 16, 2021Star
Onouris you called Netgear support?
If you did I'm guessing they denied the issue was with their firmware.
- robjakAug 17, 2021Luminary
The issue is that there is no way to get support for routers that are past their complimentry support period (90 days i think). There is no email or phone support). Kind of depressing. I have been contacted via another post for "actual Level 2 NETGEAR support" but i am now on a 12 day vacation so i am not sure if anything will happen fast. Others may also have contacted the moderator.
That post is here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/DNS-gt-PROBE-FINISHED-NXDOMAIN-error-since-latest-update/td-p/2123701/page/2
There is reply from a moderator. You all should follow the direction from that reply.
I do believe that NETGEAR does know about an issue and may be working on it. More people need to let them know. The problem is it seems this community forum may be the only way let them know.
***NETGEAR broke their DNS in the latest FW release for many routers. Manually setting DNS on clients is not a fix. Rolling back FW to a security flawed version is also not a fix. Demand that they fix it.
- Hopper15Aug 17, 2021Star
I bought a two year extended warranty from Netgear for my router. Unfortunately the support period for that warranty ended like 4 or 5 months ago.
