Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
curlykid1
Aug 18, 2021Initiate
Same problem here with the latest firmware 1.0.4.74 DNS fails to resolve when browsing. Fix your garbage update Netgear!
Winancy
Aug 22, 2021Apprentice
I have been dealing with this same issue for several weeks now. Factory reset, reverting to the previous firmware, and all the other flushing and renewing hasn't corrected the problem. I've been contacted by Netgear support and worked with them twice. Changing to Google DNS, clearing caches, factory reset, and a whole bunch of other things read off the script. When she suggested that I turn off my firewall and anti-virus and I refused, she said to call my ISP because that's probably what the problem is.
I ordered a new router. Not Netgear. It arrives tomorrow. I hope it solves the problem.
- Hopper15Aug 23, 2021Star
Wow she suggested you turn off your firewall and AV.
- rdrieseAug 23, 2021Aspirant
Just chiming in. I am having the same issues since the 74 update. I rolled back to 68 and same deal now. I work from home and am extremely aggravated by this. Hoping that Netgear updates and fixes this asap. If not, I will be purchasing a router from a different company asap.
- Hopper15Aug 31, 2021Star
Still nothing from netgear. smh
