Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
nethog
Sep 24, 2021Guide
I asked the same question earlier in this thread but nobody responded so I guess no Netgear does not support us even though they created the issue. Very sad, I used to think Netgear was a great company until this incident.
mariemorgan
Mar 15, 2022Aspirant
Same issue still in March 2022.
- FURRYe38Mar 15, 2022Guru - Experienced User
- nethogMar 15, 2022GuideWell I have been using v1.0.4.68 successfully since the x.74 debacle and have no plans to change - if it ain't broke don't fix it. Actually my next change will be buying a non-Netgear router, i.e. from a company that actually supports its customers
- mariemorganMar 15, 2022Aspirant
Thanks that worked!
- Sylm3Apr 01, 2022Tutor
Hi
a new firmware is available on 3/30/22 : R8000 Firmware Version 1.0.4.84
Hope the DNS fix is included
I have actually rolled back to 1.0.4.68 and everything is OK but i'm worried to aply this new one
Release Notes is very very lightSecurity Fixes:
- Fixes security vulnerabilities.
If someone test this new firmware and have a feedback 🤓
