Mike_Soda
Apr 14, 2022Aspirant
7800 Client Mode?
Is it possible to setup my R7800 as a client? I used to have my own connection through Sparklight I originally bought it for a couple years ago. Unfortunately now I'm in an appartment & trying to avoi...
Apr 14, 2022Guru - Experienced User
You already have your own router/wifi in the apartment? you just want the r7800 to connect to it so you can hardwire a pc into the r7800?
Is that correct?
https://kb.netgear.com/25599/How-do-I-set-up-my-Nighthawk-X4-to-Bridge-mode
- Mike_SodaApr 15, 2022AspirantYes & no, the router/modem combo that's providing wifi in my appartment is upstairs in my landlords area. It's just one of those combo units leased from Sparklight. Probably a Hiltron CGNM-2250. Yeah I want my 7800 to connect to it wirelessly so I can just plug my desktop pc into my 7800.
- FURRYe38Apr 15, 2022Guru - Experienced User
Should connect fine.
- Mike_SodaApr 15, 2022AspirantUnfortunately it wont, settings attempt to apply but then the page refreshes & says unable to connect. From that point forward I can't log into my modem at all. Acts as if it's bricked, have to use that tiny pin reset button on back to reset the modem to factory defaults.
