floydo
Aug 14, 2018Aspirant
7800 firmware corrupted tftp.exe recovery fails
Recently updated from V1.0.2.46 to V1.0.2.52 by downloading file and using interface to update from PC. (For some reason when using router interface the newer firmware check reported no new firmware...
- Aug 14, 2018
I was able to restore to the 46 version. Found https://forum.openwrt.org/t/r7800-back-to-stock-firmware/13973/7 link and used TFTP.exe command line to restore after doing a reset by holding in the reset, powering on the router, then when the orange light turns white blinking released the reset button. There were several other attempts but this worked.. The tftp2.exe did not even after trying this reset method....
Hope this helps someone else....Will try the 52 version firmware when I get some time.....
myersw
Aug 14, 2018Master
Just for giggles and grins try without any password. That worked for me.
- antinodeAug 14, 2018Guru
> [...] (19841). [...]
Do you mean this KB article?: https://kb.netgear.com/19841See:
https://community.netgear.com/t5/x/x/m-p/1533866
That thread refers to a particular KB article:
https://kb.netgear.com/22688/
which Netgear (in its wisdom) seems to have removed, leading to a
blank/useless error page, rather than to its apparent replacement:
https://kb.netgear.com/000059633/
Also:
https://kb.netgear.com/000059634/
> [...] try without any password. [...]
The first "T" in "TFTP" is for "Trivial". So far as I know, TFTP
does not use a password. That's part of "Trivial". I have no idea what
those "Download and install [...]" programs do with a password, which is
one more reason to use a simple, command-line TFTP client program. - floydoAug 14, 2018Aspirant
Thanks Bill, I did try that and it didn't work either (using the original start router and use tftp2.exe before the white blinking power method).
