geaux124
Jul 20, 2019Aspirant
7800 or 7900p?
I am replacing the router in my home and thought I had decided on getting the 7800 but then saw that I could get a 7900p for the same price. I do not particuarly need a tri band router but I have be...
- Jul 20, 2019
Currently the R7800 is the best router you can get from NETGEAR. It has the best range (according to tests by SmallNetBuilder) and stable, decent firmware. It's also a Qualcomm-based router which means its firmware is based on OpenWrt as that's what Qualcomm uses for its SDK.
Performance-wise, the R7800 beats the R7900P as it uses a quad-core CPU which 2 cores at 1.7 GHz dedicated to applications and firmware and 2 cores at 800 MHz as network packet processors
The R7900P is Broadcom-based with a dual core CPU at 1.8 GHz but uses CTF (cut through forwarding) for acceleration and CTF is not compatible with many things thus it gets disabled if you use QoS, Traffic Meter, port forwarding, etc - basically anything that needs to inspect packets first, disables CTF
microchip8
Jul 20, 2019Master
- geaux124Jul 20, 2019Aspirant
Thanks so much for the information.
- michaelkenwardJul 21, 2019Guru - Experienced User
.... and microchip8 is not alone in preferring the R7800, you will find quite a lot of people here saying the same thing. It is a versatile and reliable router. So much so that Netgear used it as the "hardware engine" for the XR500, its first foray into gaming routers.
