checktravis1's avatar
checktravis1
Follower
Feb 27, 2017
802.11ad usb adapter
What do i need for my surface pro 3 (or anything with usb 3.0) to take advantage of the 60gz of the r9000?
    • William10a's avatar
      William10a
      Master
      Wouldn't the data transfer rate limit of the usb3 port limit a based usb3 ad adaptor to the 4.8gb data transfer rate as well even if every was work just right and no  bottle necks anywhere in the data bus even if you had the perfect line of sight and in the perfect range from the router or I'am wrong?
      • schumaku's avatar
        schumaku
        Yes, of course. However, with all these shared media technologies (the air) and with the massive concurrent multi-channel as we see on the 2.4 GHz (even overlapping channels) and on 5 GHz (160 MHz, soon even more), the aim is to have a reliable, fair usage access. For now, you would get these marketing data rates on very short distances only, ie on a desk with these 802.11ad based docking stations - withing some 10...50 cm only. Thus, the USB 3.0 limitation won't hit very soon.
