FormatC
Oct 13, 2021Tutor
*8500 Antenna Came Apart How to fix?
Hi there long time Netgear user (My first newly bought router was my WNDR4500) anyway I bought a used R8500 router online and it was packed too well as in I was unwrapping it from it's bubble wrap (i...
- Oct 13, 2021
Just curious. It had to have come out half decently for the connections to be intact. so it'd have to go back in half decently.
My understanding is the board is there because its an amplified antenna.
the housing is just a protective. you don't *need* it but it should go back on without to much force or it wouldnt have come off.
Oct 14, 2021Guru - Experienced User
glad you got it back on!
Hope it works great for you!
FormatC
Oct 14, 2021Tutor
Yet got it configured last night with DD-WRT as I heard of the "Bricking" issue with the Netgear Genie firmware but I think DD-WRT is missing some features mainly 5GHZ WiFi single smart mode and LED control.
I have the 400 (MBPS MB?) I forget which alphabet soup letter they use but it seem much faster even with my wired (most of my stuff) stuff.
I mostly use WiFi for stuff that lacks an ethernet port.
