skclarey's avatar
skclarey
8500 Port aggregation NIC card for PC
I have the R8500 and want to know if there is a Network Card I can get for my pc, with dual ports, that would allow aggregation between the router and my PC?
  • netwrks's avatar
    Oct 26, 2016
    Can always try the big box stores or maybe Amazon, etc. Unless you are moving TeraBytes of data off / on your PC, you will never realizw the benefit from dual gig NIC cards. You would have to saturate one link first before LAG would actually kick in.. Typically used for NAS Servers and the like..
