Swerve83
Aug 25, 2018Apprentice
8TB Hard Drive on Nighthawk X8 R8500
Does the Nighthawk X8 (R8500) support 8TB Hard Drives??????? My 5TB WD My Book is no longer supported it seems on the USB 3.0, but it works on the USB 2.0 port. I am upgrading to a large storage any...
- Aug 26, 2018
You can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
You may be pushing it with 8TB drives.
For serious networking use Ethernet.
michaelkenward
Aug 26, 2018Guru - Experienced User
Swerve83
Aug 26, 2018Apprentice
Yah I ran across this link earlier. Figured 8TB would be pushing it. Eventually I will be using a swich with rack holding 5-10 drives, totaling around 36TB.
Thanks for your reply!
