aGuyy's avatar
aGuyy
Follower
Dec 29, 2021
A6150 connections issues
Hi, I am having some internet connection trouble with usb mini adapter. I had another one that worked fine (which I lost. It was an amazon product so I don't remember the name.) but this one only gives 20 mbps and sometimes less while my router is emitting 300 mbps. When i'm talking in discord or play video games I have 3 seconds lag spikes every 10 seconds.
- I tried to disable the save power thing.
- I tried reinstalling drivers.
I am sure it isn't my computer because the other one gave me around 150 mbps.
Thank you,
Guy.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Many issues that crop up here are generic: they apply to a load of devices, especially when they involve routers. However, USB adapters don't have much in common with the Nighthawk WiFi Routers covered here.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    WiFi Adapters - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
