HJTeix
Oct 06, 2021Guide
AC 1000 ROUTER NTP SERVER NOT WORKING.
Warning: The router is failed to connect to NTP server, please check your Internet connectivity or try another NTP server. I tried many server but none connect. The router is working good Thank you...
HJTeix
Oct 13, 2021Guide
I switched from .48 to .52 and the problem disappeared, but the 403 Forbidden one didn't!
- FURRYe38Oct 13, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.- HJTeixOct 16, 2021Guide
Solved ?? Because if nothing has been resolved!
Resetting does not solve this problem !! I and many people need a new firmware to fix the 403 error problem !!
- FURRYe38Oct 16, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalI would contact NG support as well as this needs to be resolved by NG themselves.
Good Luck.
