HJTeix
Oct 06, 2021Guide
AC 1000 ROUTER NTP SERVER NOT WORKING.
Warning: The router is failed to connect to NTP server, please check your Internet connectivity or try another NTP server. I tried many server but none connect. The router is working good Thank you...
Oct 13, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
HJTeix
Oct 16, 2021Guide
Solved ?? Because if nothing has been resolved!
Resetting does not solve this problem !! I and many people need a new firmware to fix the 403 error problem !!
- FURRYe38Oct 16, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalI would contact NG support as well as this needs to be resolved by NG themselves.
Good Luck.
