Adryan475
Jan 06, 2021Aspirant
AC 1200 Smart Wifi Router, Images not loading
Okay so as I said I have that router and I updated to the new firmware (V1.1.0.106_1.0.1) and now images are not loading on Instagram, Facebook etc... ive check on both my iPad, iPhone and comput...
Jan 07, 2021Guru - Experienced User
What modem do you have?
What router do you have? AC1200 is a speed, not a model.
did you every try downgrading the firmware? maybe the firmware introduced a bug in your setup
- Adryan475Jan 07, 2021Aspirant
plemans The model is r6230 and i didnt downgrade the firmware, not sure how im even supposed to do that
- plemansJan 07, 2021Guru - Experienced User
to downgrade you simply download the older firmware, unzip it, and then follow the manual firmware update process from the manual. you just use the firmware you downloaded
ok well i did it just now and im still having the same problem unfortunately...I still have interent access and can load websites fine, but again Instagram i can message people but no pictures are loading and Youtube is loading as well but videos are not playing.
