Adryan475
Jan 06, 2021Aspirant
AC 1200 Smart Wifi Router, Images not loading
Okay so as I said I have that router and I updated to the new firmware (V1.1.0.106_1.0.1) and now images are not loading on Instagram, Facebook etc... ive check on both my iPad, iPhone and comput...
Jan 07, 2021Guru - Experienced User
What modem do you have?
What router do you have? AC1200 is a speed, not a model.
did you every try downgrading the firmware? maybe the firmware introduced a bug in your setup
Adryan475
Jan 07, 2021Aspirant
plemans The model is r6230 and i didnt downgrade the firmware, not sure how im even supposed to do that
- plemansJan 07, 2021Guru - Experienced User
to downgrade you simply download the older firmware, unzip it, and then follow the manual firmware update process from the manual. you just use the firmware you downloaded
- Adryan475Jan 07, 2021Aspirant
ok well i did it just now and im still having the same problem unfortunately...I still have interent access and can load websites fine, but again Instagram i can message people but no pictures are loading and Youtube is loading as well but videos are not playing.
what modem do you have?
