CapJT
Oct 16, 2021Aspirant
AC 1200 Smart wifi router with external Antennas Model R6220; Firmware Version V1.1.0.110
AC 1200 Smart wifi router with external Antennas Model R6220; Firmware Version V1.1.0.110 Based on an email received from Netgear on/around 09-October-2021, I updated the firmware of my Netgear ...
Oct 16, 2021Guru - Experienced User
Are you using IPv6?
What modem/gateway is it connected to?
- CapJTOct 16, 2021Aspirant
Hi, Tks for ur response;
As far as I can ascerttain from the service provider
Are you using IPv6? - Yes as informed by the service provider
What modem/gateway is it connected to? - Broadband 100 Mbps - Fibre cable connected to
Router Netgear AC 1200 Smart wifi router with external Antennas - Model R6220
- plemansOct 16, 2021Guru - Experienced User
Are you using IPv6? - Yes as informed by the service provider---Is it enabled in your router? Thats the key.
Router Netgear AC 1200 Smart wifi router with external Antennas - Model R6220-----The R6220 isn't an ONT ( the fibre connects to something the router connects to)
Hi Sir,
Thanks again for your response;
Sir can you advice how I can verfiy this on my router R6220
Yes indeed ; the fibre is connected to a SEE (subscriber end equipment - which is marked as Ipv6 ready - Make/Model: Optilink /
(OP-XONT 71000)) which inturn is connected to the router.
