KristianSolem
Jun 10, 2017Aspirant
AC 1750: Ready Share Vault doesn't see usb drive. Model R6400.
I set up the new PC and connected it to the router via LAN. I downloaded Genie and Ready Share. Choose backup drive shows me all the drives on my computer but not the one plugged into the router. It ...
- Jun 11, 2017
REPLY TO MY OWN QUESTION:
I reverted to the firmware the router came with, V1.0.1.12, everything works perfectly...
Jun 11, 2017Guru - Experienced User
Did you do a factory reset before and after sending the FW file then set up from scratch?
