mariadwyer
Apr 13, 2022Follower
AC or AX for my new router?
I'm currently looking for a new router as the one provided by my internet provider keeps cutting out from the amount of devices we use. (4 phones, 3 Gaming consoles, 2 laptops, 7 Google Home devices,...
Apr 13, 2022Guru - Experienced User
I'm a fan of having to much capability versus not enough. and if you're referring to the R8000, it was released in 2014. Its still plenty capable but i'd be choosing an AX router over it. I'd even try looking at amazon as theres a bunch of renewed AX netgear routers on there. Everything from the orbi series to the AX5700. (thats version you have to search by the speed and not the model to find the renewed)
but most half decent routers should support the devices you have listed.
What speeds do you pay for?
What modem/router/gateway's do you currently have?
What actually happens when you're having issues?
Does the issue happen to wired and wireless devices or just wireless?
- microchip8Apr 13, 2022Master
I'd go for an AX router too, if I need to buy a new one.
