pqfuller
Feb 02, 2021Follower
AC1200 / R6220 - 5G connects briefly, then drops and disappears from available networks; 2.4GHz fine
I am going to add my name to the list of people suffering from 5G wifi drop woes. Here are the details: AC1200 / R6220 running latest firmware V1.1.0.106_1.0.1 Home network consisting of: 1....
DarrenM
Feb 17, 2021Sr. NETGEAR Moderator
It could be a hardware issue if this issue started happening and it worked just fine in the past I suggest you contact support and see if the router is under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
