obelisk1111
Oct 11, 2021Guide
AC1200 C6230 Modem/Router Drops Internet Several TImes per Day, Have to Restart
I have now used 2 of the same modem. I returned and replaced the first one I bought to rule that out as the issue. Both modems have had the same problem. The internet works great most of the time, bu...
Oct 12, 2021Guru - Experienced User
do you have a screen snip of the event log and the cable connections page? That lets us check the signal.
Things you can do to help prevent the cable company from charging you.
1. move the modem to right where the signal/coax enters the home.
2. remove any splitters, amplifiers, or signal attenuators from the line.
3. check the line for kinks, damage, old/loose/corroded/cheap/bad connections and replace them if you do.
By moving the modem, you've ensured the lines in the home isn't causing the issue. If when you move it, the signal improves and your issues clear up, then you know its the wiring in the home and not from the isp. So get a screen snip now and when you move it to compare.
obelisk1111
Oct 12, 2021Guide
Thanks for the response. I just moved into this house I'm renting at the beginning of September. There is only one cable in the house, my desk is right next to it. No splitters or anything else on the cable line, which is buried in the wall. The modem is as close to the cable as is possible. My main device is a desktop computer, and I run an ethernet cable from the modem/router directly into the computer. The only other active device is my phone, which is on the WiFi signal. When the Internet cuts out both the computer and phone drop the internet connection, so it's impacting the WiFi and ethernet the same way. This is the cable connections page and most recent event log:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 579000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv4 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 17 | 579000000 Hz | 7.4 dBmV | 40.0 dB | 0 | 0 |
| 2 | Locked | QAM256 | 3 | 489000000 Hz | 7.4 dBmV | 40.3 dB | 0 | 0 |
| 3 | Locked | QAM256 | 4 | 495000000 Hz | 7.5 dBmV | 40.2 dB | 0 | 0 |
| 4 | Locked | QAM256 | 5 | 507000000 Hz | 7.5 dBmV | 37.8 dB | 0 | 0 |
| 5 | Locked | QAM256 | 6 | 513000000 Hz | 7.8 dBmV | 40.3 dB | 0 | 0 |
| 6 | Locked | QAM256 | 7 | 519000000 Hz | 7.4 dBmV | 40.2 dB | 0 | 0 |
| 7 | Locked | QAM256 | 8 | 525000000 Hz | 7.6 dBmV | 40.3 dB | 0 | 0 |
| 8 | Locked | QAM256 | 9 | 531000000 Hz | 7.3 dBmV | 40.1 dB | 0 | 0 |
| 9 | Locked | QAM256 | 10 | 537000000 Hz | 7.3 dBmV | 40.1 dB | 0 | 0 |
| 10 | Locked | QAM256 | 11 | 543000000 Hz | 7.0 dBmV | 40.0 dB | 0 | 0 |
| 11 | Locked | QAM256 | 12 | 549000000 Hz | 7.1 dBmV | 40.0 dB | 0 | 0 |
| 12 | Locked | QAM256 | 13 | 555000000 Hz | 7.0 dBmV | 40.0 dB | 0 | 0 |
| 13 | Locked | QAM256 | 14 | 561000000 Hz | 7.3 dBmV | 40.0 dB | 0 | 0 |
| 14 | Locked | QAM256 | 15 | 567000000 Hz | 7.4 dBmV | 40.1 dB | 0 | 0 |
| 15 | Locked | QAM256 | 16 | 573000000 Hz | 7.1 dBmV | 40.0 dB | 0 | 0 |
| 16 | Locked | QAM256 | 18 | 585000000 Hz | 6.6 dBmV | 39.9 dB | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 35600000 Hz | 44.0 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 29200000 Hz | 43.0 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 22800000 Hz | 42.8 dBmV |
| 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 16400000 Hz | 42.8 dBmV |
| 2021-10-11, 10:57:14.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.1;CM-VER=3.0; |
| 2021-10-10, 17:04:52.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.1;CM-VER=3.0; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.0;CM-VER=3.0; |
- plemansOct 12, 2021Guru - Experienced User
Your power levels look pretty spot on.
You can get some t3/t4 errors when its first booting/connecting and you have that.
And you don't have any errors. If this was booted up yesterday and your not showing errors and just the bootup t3/t4, it'd keep watching it until you get the errors, then log in and get the logs/signal connections.
Sometimes it can be an intermittent issue. I had a guy that only had issues when the wind was blowing to hard because it'd blow his coax cable (run overhead) into some trees and a hole had worn into the cable.
but so far the signal doesn't look to bad. Who's your isp?
Could be them pushing for docsis 3.1......
- obelisk1111Oct 12, 2021Guide
My provider is Xfinity/Comcast. The modem they rent out is a 3.1, my modem/router is Docsis 3.0. Could that be the issue? I bought the modem/router myself. I can still return the modem/router but only have a few more days before I'm stuck with it. Should I buy a 3.1 docsis modem/router? I don't really know what the difference is between 3.0 and 3.1, could you offer a brief explanation? Thanks again for your help :)
Docsis 3.1 has higher throughput and more ISP's are requiring it for decent speeds. For examply, cox recently started pushing it for speed tiers over 150mbps. There's a bunch more info than that but quick google search can go into details.
https://pickmymodem.com/all-about-docsis-3-1-and-docsis-3-1-cable-modems/
If it was me? I'd return it and buy a docsis 3.1 modem only device. Then I'd buy a router.
the combo devices firmware is controlled by the isp and there isn't much for troubleshooting to see if its a modem issue versus a router issue. It tends to have a higher upfront cost (for same specs devices) but leaves you in control of your firmware as well as allows you to upgrade just 1 piece of it if you're needing improved speeds. but it is a significant cost increase going from docsis 3.0 equipment to docsis 3.1
Is that whats causing the problem though? Tough to really know.
An option worth trying?
Return the C6230 and rent xfinity's modem/router device for a month. Might cost you $10-20. But if it works well, then you know the line is fine and can look around for a docsis 3.1 device. If it doesn't work well, xfinity can't blame the device because if 2x 3rd party devices had issues and so does theirs, then it doesn't leave much besides the line.
