Gaet
Dec 23, 2020Follower
AC1200 ex6130 connexion bridé
Bonjour, j'ai acheté le répéteur il y a 1 an et demi environ, a ce moment tout allez bien mais aujourd'hui sur m'a installé la fibre donc une plus grosse connexion, a la sortie de la box j'ai 220...
Dec 23, 2020Guru - Experienced User
Its a misunderstanding of how extenders work.
They take at minimum (single/dual band extenders) a 50% speed reduction. this happens because they have to go router----->extender and then extender------>devices and they can't do both at once. So their speed is half of what they get.
So if you're putting in 220mbps, 100mbps is about what you can expect out (because its probably not getting the full 220 mbps your router puts out because of interference/distance)
Also, 2.4ghz won't hit 300mbps. Thats link speed and not throughput. You're doing good to hit 50mbps over 2.4ghz on an extender.
