HBmoln
Jul 20, 2021Initiate
AC1200 model ex6120
I have a range extender model EX6120, is it possible to extend network from one extender to another?
Jul 20, 2021Guru - Experienced User
Is it possible? Yes
Will it cause increased latency and drop your speeds? yes.
Single and dual band extenders have to use the same chip to go router---extender and then extender----device. And they can't do both at once. So their speed is 50% of what they recieve. Add another extender to it and its at less tahn 25% of what your actual router speed is.
Its why you see the push for triband mesh systems.
HBmoln
Jul 21, 2021Initiate
Thanks
