treesRfriends
Dec 17, 2020Aspirant
AC1200-R6220 VPN Passthrough
I have contacted my IT professional at work and they could not help me (just said "the router's blocking it"), so I have no other choice than to try and fix myself. I am not a computer whiz, but I ca...
treesRfriends
port forwarding snip since I couldn't include two attachments
- plemansDec 17, 2020Guru - Experienced User
You can always cheat and put the computers IP address in the routers DMZ. This forwards everything to the router. not a safe option but it'd get you up and running. Everything between the work computer and work should be encrypted through the vpn anyway.
- treesRfriendsDec 17, 2020Aspirant
Can you tell me how I can do that. Thank you.
Any idea on long-term solutions or why the router is doing this?
