butlerds's avatar
butlerds
AC1200 R6230 can't connect as access point
Brand new R6230.  Trying to connect as Access Point.  Followed directions, but no Internet access.  Device is showing up in my main router as R6230, IP 192.168.1.145, but shows as inactive.   Tri...
  • butlerds's avatar
    butlerds
    Apr 15, 2019
    Apparently, the router is very sensitive to cable length.  Brought it downstairs and connected it to a port with a shorter cable and it worked immediately, just like the instructions.  Was able to connect to the Internet and then put it into access point mode in about two minutes.
    Yes, both cables run directly to the master router (a G1100), and yes multiple routers from other manufacturers have had no problem connecting in either room (a Linksys E1200 is upstairs now).  And no, the firmware version had no effect (tried .68, .80, and .86 in both rooms).
    So just a tidbit to keep in mind about this particular router.
