butlerds
Apr 14, 2019Aspirant
AC1200 R6230 can't connect as access point
Brand new R6230. Trying to connect as Access Point. Followed directions, but no Internet access. Device is showing up in my main router as R6230, IP 192.168.1.145, but shows as inactive.
Tri...
- Apr 15, 2019
Apparently, the router is very sensitive to cable length. Brought it downstairs and connected it to a port with a shorter cable and it worked immediately, just like the instructions. Was able to connect to the Internet and then put it into access point mode in about two minutes.
Yes, both cables run directly to the master router (a G1100), and yes multiple routers from other manufacturers have had no problem connecting in either room (a Linksys E1200 is upstairs now). And no, the firmware version had no effect (tried .68, .80, and .86 in both rooms).
So just a tidbit to keep in mind about this particular router.
michaelkenward
Apr 15, 2019Guru - Experienced User
butlerds wrote:
Tried power cycling the R6230 but no good.
Tried power cycling the whole network, including whatever router sits bvefore the R6230?
And do it in the right order:
- Turn off and unplug modem.
- Turn off router and access point.
- Plug in modem and turn it on. Wait 2 minutes.
- Turn on router and wait 2 minutes.
- Turn on access point
- butlerdsApr 15, 2019Aspirant
- schumakuApr 15, 2019Guru - Experienced User
When reading this I would be more suspect about the cable and installation quality.
Just curious - beyond the "I had one at hand" - why adding routers (which make crappy wireless APs) instead of inexpensive wireless access points?
"Cable and installation quality". Ha ha ha! Like most installations, it was the exact same cable and same installer. And no other router has ever has the same problem. So doesn't take a genius to figure it out. Cable length matters.
A router makes a fine access point, and it was cheap ($50). And routers are more flexible so I can use them in other scenarios if/when I change my mind in the future. But if you'd prefer buying access points, can't blame you.
