Stimpy
Oct 31, 2021Aspirant
ac1600 nighthawk drops internet connection to my android phone. network shows the printer instead
My new (less than 2 weeks) ac1600 router works well then it will drop my internet connection to my samsung android phone. When I look at the network my phone is connected to it shows I'm connected t...
- Nov 01, 2021
1. We still don't know what router you have.
2. You're neighbors setup is going to be with different because its with a different isp.
3. what modem/gateway is your router connected to?
4. did you go into your devices and forget the printer?
5. Did you setup the printer to connect to the router and not using wifi direct?
Nov 01, 2021Guru - Experienced User
A couple things.
1. What router do you have? AC1600 is a speed, not a model
2. Why not go into your phone and "forget" the printers wireless?
3. why isn't the printer just connected to the network instead of broadcasting its own wifi network for "wifi direct" printing?
Stimpy
Nov 01, 2021Aspirant
I thought the model was the AC1500.
I hadn't had trouble with the phone dropping or being changed to the printer until I replaced the router 2 weeks ago.
I helped a neighbor with an identical upgraded router and she informed me that her phone showed no internet access also. She said that after she power cycled her router her Iphone reconnected to her router. Her home is 6 houses away, and she subscribes to a different ISP than I do.
Because this issue is similar to my neighbors I thought I may have incorrectly set up both of the routers.
I used the Nighthawk application to set them both up individually.
- plemansNov 01, 2021Guru - Experienced User
