Stimpy's avatar
Stimpy
ac1600 nighthawk drops internet connection to my android phone. network shows the printer instead
My new  (less than 2 weeks) ac1600 router works well then it will drop my internet connection to my samsung android phone. When I look at the network my phone is connected to it shows I'm connected t...
  • plemans's avatar
    Nov 01, 2021
    1. We still don't know what router you have.
    2. You're neighbors setup is going to be with different because its with a different isp.
    3. what modem/gateway is your router connected to?
    4. did you go into your devices and forget the printer?
    5. Did you setup the printer to connect to the router and not using wifi direct?
