kpaw333
Dec 17, 2020Aspirant
AC1750 / R6350 Issues after firmware update
Hey guys, I'm having a time with my router. It's been mostly fine for a while now. Every once in a while, it loses an internet connection and a simple reboot helps. Then last night happened. I we...
Dec 18, 2020Guru - Experienced User
If it coincided with the firmware update, you can always try downgrading the firmware.
simply download the old firmware and follow the manual update process (from the manual) to install it.
