SJ2006
Jan 23, 2021Follower
AC1750 Devices are saying my security is weak
My devices are showing weak security. Says I should use wpa2 or wpa3. How do I change my router to this.
Jan 25, 2021Guru - Experienced User
The C6300 wont' support wpa3. Its a new standard and would require new hardware.
You can change the wireless security settings through the wireless settings in the browser.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
