Derrik
Mar 08, 2021Follower
AC1750 Dual Band extender
Just purchased this extender, do all the devices have to be connected to the Netgear.Ext, or can I leave some devices connected to the Nighthawk router directly
Mar 08, 2021Guru - Experienced User
You can seperate them out between the 2.
You could also enable "onewifi" on it and let the devices themselves roam between the 2 if you choose.
the "onewifi" feature is the mesh component.
