PShooter
Feb 23, 2021Aspirant
AC1750 Model: R6700v3
I lost the internet connection and the internet light is amber. I have tried powering down and restarting several times with no result.
michaelkenward
Feb 24, 2021Guru - Experienced User
As this is a router, there is probably a modem sitting in front of it. Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
PShooter
Feb 24, 2021Aspirant
Thanks but I have already tried that procedure but it’s not working.
- michaelkenwardFeb 25, 2021Guru - Experienced User
What else have you tried but can't be bothered to tell people?
Your first message provides next to no useful information.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
