Lilibet
Apr 20, 2021Follower
AC1750 Netgear R6400 slow internet speed
When I setup my new router I now have two networks(not on purpose I am a bit clueless) My wireless connections to devices are slow and drop frequently. I did update the firmware which helped for a whi...
Apr 20, 2021Guru - Experienced User
So we need a bit more infomation.
You have the R6400?
What firmware is on it?
What modem/gateway is it connected to?
When you say "you have 2 networks" are you talking about the 2.4ghz and the 5ghz network or does your gateway also have a network as well?
FYI 2.4ghz is a slow network. It won't be nearly as fast as 5ghz and is more sensitive to interference.
