smokerise411
Feb 13, 2021Aspirant
AC1750 R6400 Ruko streaming buffering constantly
I have a Ruko TV that I can not watch because it buffers constantly. My provider says it my router. And of course Netgear wants my to pay for 6 months of support to help me fix it. I am not a compu...
Feb 14, 2021Guru - Experienced User
What roku tv model is it?
How far from the router are you and whats in the all (wall/objects/what are they made of?)
Are you trying to stream over 2.4ghz or 5ghz?
- smokerise411Feb 15, 2021Aspirant
Ruko model NS-24DR220NA18 - TV and netgear router are in the same room. No walls. Appprox. 12 ft apart
- plemansFeb 16, 2021Guru - Experienced User
I couldn't find if that tv is single or dual band.
If its single band, try hardwiring in the tv. If its dual, make sure you're on the 5ghz.
