adamisconfused
May 26, 2021Aspirant
AC1750 R6400v2 firmware update does not have exe file in download
I went to this website to download the latest firmware update. The download has a release notes file and a .chk file. I am using a Mac. Where can I get the exe file to execute? I would just use route...
adamisconfused
ahh but it needs my router admin login info which I do not have nor do I remember my security questions and since the item was purchased awhile ago, I no longer have support.
May 26, 2021Guru - Experienced User
If you don't know the login and didn't setup (or don't know) the security questions, then you'd need to factory reset to get back to the defaults
Push and hold reset for 7-15 seconds while its powered on.
Then reinstall the router.
default login: admin
default password: password
