Darkarise
Mar 19, 2021Aspirant
AC1750 R6400v2 slow speeds
Hello there I recently bought a surfboard8200 because I was informed my modem wasnt good to get my plans speeds 400 mpbs. Well my wireless speeds stay the same I use the 5g and only get up to 150 mpb...
- Mar 20, 2021Thanks again for your time I ended up being able to fix the issue by just resetting my router
Mar 19, 2021Guru - Experienced User
Link speed isn't the same as throughput speed.
Its also device dependant as well.
there's a bunch of information I could go over or you could try reading this article;
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
It goes over a lot of the misconceptions with wireless.
Darkarise
But in summary do I not believe that my router can then push out the speeds it advertised?
- plemansMar 19, 2021Guru - Experienced User
Its a sad state of how manufactures advertise speeds for wireless.
Whats more important is actual tested speeds. I usualy recommend smallnetbuilder for speedtest reviews (he's been doing less of it lately).
here's the review for your device.
NETGEAR R6400 AC1750 Smart WiFi Router Reviewed - SmallNetBuilder
If you do look for other solutions, I'd recommend reading a few tested reveiews of the units to see what actual speeds they get.
- DarkariseMar 20, 2021AspirantThanks again for your time I ended up being able to fix the issue by just resetting my router
