YummYummtheMan
Jul 13, 2021Aspirant
AC1750 R6400v2 slow wired speeds
I am getting 900mbps download directly from my Arris SB8200 modem, however when I plug in my R6400v2 Router, I'm only getting between 200 and 500 mbps download while hard wired in. I'm currently on f...
Jul 14, 2021Guru - Experienced User
Make sure after you reset that you don't restore a backup configuration.
Also, during the install leave qos, access controls, traffic monitoring, and parental controls all disabled.
- YummYummtheManJul 14, 2021Aspirant
I can confirm that my reset to default configuration did not restore old data, as the custom SSID and passwords were reset, along with my port forwarding.
