rjfrost
Apr 27, 2021Initiate
AC1750 R6400v2 slower wifi speeds than normal
I recently moved houses and upgraded from 200 Mbs to 400 Mbps. My lan speeds reflect the increase in speeds. The wifi however is much slower than it was before. I was getting 200 Mbps before and now ...
- Apr 28, 2021
1. don't disable wmm.
2. did you try a factory reset? Push and hold reset for 7-15 seconds while its powered on.
3. what modem/gateway do you have?
Apr 28, 2021Guru - Experienced User
rjfrost
Apr 29, 2021Initiate
Okay I did a factory reset and things seem more reasonable now (200 Mbps on phone, 360 Mbps on computer). I will mark as solved.
The modem is an Hitron EN2251.
