tangomango's avatar
tangomango
AC1750 R6700v2 indicator lights don't work right?
Hello Friends,   I connected two external devices via ethernet cable to my ports 3 and 4 (a TV and a Roku player). Both devices seem to pull decent speeds, no delays noticed right now, but the ligh...
  • antinode's avatar
    Mar 24, 2018
    > [...] the lights on the router are orange/amber and not white. Why is
    > that happening?
       Perhaps for the reason explained in the documentation.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "LED and button
    descriptions".
          The LED color indicates the speed: white for Gigabit Ethernet
          connections and amber for 100 Mbps or 10 Mbps Ethernet
          connections.
       Additional reading might be beneficial, too.
