Jackmac60
Mar 02, 2024Aspirant
AC1750, R6700v2, strange behavior on powerup
When I do a reset the first light to come on is the broadcast light for several seconds then it goes out and the amber power light comes on. I think my firmware has been compromised. Am I on the right track?
Because of how the led lights up, you think you're router is compromised?
Do you have any other indication of that?
- Jackmac60AspirantMany, previous very stable connection keeps resetting. When I do finally get to router dashboard multiple windows keep coming up asking for my admin pw. Then it resets and asks me to change admin after many attempts disregarding windows. When I start to investigate things like Mac address it drops out. Found the Mac address to be different than what is on label of machine. So if the led behavior means something definitive that would help with my decision to replace router. I don't see a way around this type of firmware corruption.
Have you tried a simple factory reset and reinstall?
