axltl23
May 07, 2023Tutor
AC1750 R6700V3 Keeps Dropping 5G Wifi Every Day with Spectrum
I'm currently having a problem with my router dropping 5G wi-fi every now and then. It'll be up for a few hours but randomly shuts off and stays off for about the same amount of time it was up for. T...
axltl23
May 10, 2023Tutor
I did try changing the wifi channel, because the 5G was on channel 149 before switching it to 153, but I still had the same problems.
The router is sitting on a little side table in the corner of our guest room, so I think its ventilated well.
The only thing I haven't tried is a factory reset. Hoping this works! crossing my fingers 🤞
May 10, 2023Guru - Experienced User
Try the lower 40's channels. With channel overlap, they'd still be broadcasting on the same region with those.
- axltl23May 15, 2023Tutor
So I tried factory resetting the router and set everything up through the app again, but it did the same thing and went out randomly again. I tried changing the channel of the 5G down to 44, and it came up, but my speeds dropped by about 50-60 mhz. Is this normal? and if none of these solutions work, do you think it could be a problem with the modem or provider?
