Tship
Feb 19, 2022Aspirant
Ac1750 r6700v3 Recently during use it just drops me off the internet, a few secs later works
When using the internet it periodocally just stops working and says no internet connection. when I click reload it usually comes right back on. sometimes if i just wait a few seconds it just resume...
Tship
Feb 20, 2022Aspirant
My Ookla speed test on the pc which is hard wired to router:
ping 16, Download 96.1, Upload 10.14
I also ran it on my iphone which is on wifi through the router
Ping 20, Upload 237.53, it does not show an upload speed. Shouldn't it show ul speed?
Ping 16 DL 96.1 Mbps and UL 10.14Mbps on my pc are probably all I really, but I have to ask why is my DL speed much faster on my phone which is connected only by wifi, than my pc which it directly connected with an ethernet cable? Also why don't i show an up load speed on the phone speed test?
Thanks again.
Feb 20, 2022Guru - Experienced User
what pc is it?
Wondering if its only got a fast ethernet connection (10/100)
- TshipFeb 20, 2022Aspirant
Dell inspiron 15-5000
- plemansFeb 20, 2022Guru - Experienced User
there's a few in that series. got the model number off the label?
Did you try a different ethernet cable?
Just purchased and installed Ethernet Cable 10 ft, Cat 8 Shielded High Speed Ethernet Cable 40Gbps with Gold Plated Plug SFTP Wires CAT8 RJ45 Connector Gaming LAN Cable for Router, Modem, Gaming, Xbox, POE, PS3, PS4, PS5, Black. did not solve the problem
