drdachel's avatar
Dec 30, 2020
AC1750 receives internet but doesn't transmit
Hi, 3    My upstairs router that is a AC 1750/R6400 recently stopped broadcasting WiFi. It has power and has a white 2nd light which I believe means it's receiving internet.  The R6400 is hard wire...
  • plemans's avatar
    Dec 30, 2020
    Well, there is a power button on it that depresses.
    but there's also a wifi on/off button on the front of it. 2nd from the right. and lights up with an led light.
    you can see it in the manual
    https://www.netgear.com/support/product/R6400.aspx
    I have a feeling you pushed the power button and not the wifi on/off button.
