kalyanraju's avatar
kalyanraju
AC1750 Smart WIFI Router - Restarting frequently after firmware Upgrade
Hi Team, I have purchased AC1750 Smart WIFI Router on 6th Dec 2018, it worked fine till the last firmware upgrade. It is restarting quite frequently. Could you please help us. Serial number : 59B3887W...
  • michaelkenward's avatar
    Jul 13, 2020
    kalyanraju wrote:
    Product: R6400v2
    It is an R6400v2. AC1750 is a wifi speed.
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    Have you tried a factory reset?
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    It will also have any firmware and drivers for your device.
    Look for the model number on the label on the device.
    Check the section in the manual on updating the firmware.
    Check the troubleshooting section in the manual.
