ncatona
Feb 03, 2021Aspirant
AC1750 V3 UPnP Enabled but Nat is still strict
So my xbox nat type is still strict even after I enabled UPnP to be turned on in the router settings. What can I do next?
- ncatonaAspirantIm doing this on a xbox one x. I have enabled the UPnP function yet the xbox still says its not connecting to the upnp and also that nat type is strict. Also I did enable ipv6 for the router but my isp doesnt support that I think since the ipv6 setting says its 6to4 tunnel so should I turn it off?
Start here:
Search - NETGEAR Communities – xbox nat
You could narrow it down to the R6700, but it is a generic issue.
