JRich99
Jul 10, 2021Aspirant
AC1750 WiFi Router (R6350) won’t set up
So, there was a tornado that hit my area and all the power went out but eventually came back on. Everything was working but was super slow so I decided to go into the app and see what was happening. I...
Jul 11, 2021Guru - Experienced User
What actual modem/gateway is it?
It if has wifi built in, it has an integrated router. it causes a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
Options? (only use 1)
1. put your modem/gateway in passthrough/modem only mode.
2. put the netgears IP address into the gateways dmz
3. put the netgear in access point mode.
