JRich99
Jul 10, 2021Aspirant
AC1750 WiFi Router (R6350) won’t set up
So, there was a tornado that hit my area and all the power went out but eventually came back on. Everything was working but was super slow so I decided to go into the app and see what was happening. I...
antinode
Jul 11, 2021Guru
> [...] The only thing showing on the Netgear router is the power button
> flashing. [...]
If you have a flashing power indicator, then you may be a candidate
for the TFTP recovery scheme. See, for example:
JRich99
Jul 11, 2021Aspirant
So, how do I fix that? I watched a YT video and when I’m in the tftp2 it says “unable to get a response from the server”
- antinodeJul 11, 2021Guru
> [...] when I'm in the tftp2 it says "unable to get a response from the
> server"First, I'd recommend using the command-line TFTP client program which
came with your (unspecified) computer OS, rather than any third-party
program.Second, the TFTP recovery scheme is a multi-step procedure which
offers multiple opportunities for user input, hence user error. By
itself, an error message doesn't say much. As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations. Especially when using a command-line program,
copy+paste is your friend.
