gdisneY46
Jul 21, 2021Follower
AC1750 will not restart
After disconnecting power for impending thunderstorm, the router will not restart. No lights come on despte turning power switch on and off, reconnecting cables. and pressing the reset button. The separate modem works.
1 Reply
Have you checked to ensure the power suppy is good? maybe disconnecting it tweaked something enough to break a wire on the supply.
